Bike Finder · Merida
Merida eONE-SIXTY LITE
Merida
eONE-SIXTY LITE 2026
CurrentLightweight · GravityMature · 5.6/10iFreshness 5.6/10
Bosch SX lightweight sibling of eONE-SIXTY
Travel F/R
170/174mm
Wheels
29F/27.5R
Frame
Full carbon
Weight
26 kg
Price
From £5,500
View the Merida eONE-SIXTY LITE on Merida’s site
Merida eONE-SIXTY LITE 2026
From £5,500
EMTB Forums verdict
The Merida eONE-SIXTY LITE 2026 is Merida's lightweight all-mountain eMTB, a carbon chassis built around the Bosch Performance Line SX motor and a 400 Wh battery. Headline numbers: 170 mm front, 174 mm rear travel, Bosch SX at 55 Nm and 600 W peak (2.0 kg), 400 Wh internal pack, a 64.4 degree head angle, reach 419 to 499 mm across five sizes (XShort to XLong) and a 446 mm fixed chainstay. The community verdict, drawing on Merida's strong reputation for handling on the full-power eONE-SIXTY (which @Mr Scooter rates as "handles beautifully" relative to the Levo, Trek Rail, Commencal and Pivot), is that the LITE variant brings that proven chassis into the lightweight tier with the Bosch SX mid-power system.
Drive system and range. The Bosch Performance Line SX is the lightweight Bosch unit at 2.0 kg, delivering 55 Nm and 600 W peak. It is the German alternative to Fazua Ride 60 and TQ HPR50, with the same SmartSystem ecosystem and Bosch Flow app integration as the full-power CX motor. The 400 Wh battery is the smaller of the two Bosch lightweight options, so range is the practical limitation: expect 25 to 35 miles on mixed terrain in Eco/Tour modes, less if using Turbo regularly. The Bosch Powermore 250 Wh range extender bottle adds an option for 650 Wh total capacity on big-day rides. Bosch dealer support is the deepest in the industry, which is a real differentiator for a lightweight eMTB.
Geometry and handling. The 64.4 degree head angle is bang on category-norm for a 170/174 mm enduro-leaning all-mountain bike. Merida uses size-naming rather than letters: XShort, Short, Mid, Long, XLong sit at 419, 439, 459, 479 and 499 mm reach with a fixed 446 mm chainstay and wheelbase scaling 1199 to 1288 mm. The five-size run is unusually granular and is one of the platform's strengths for fit. The fixed chainstay across the size run is common but not class-leading: rivals like the Ibis Oso TR offer size-specific chainstays.
Build and value. Base trim is the only listed build in current gold for the LITE variant. Merida's standard eONE-SIXTY platform has historically been good value (the 400/500 trims at the Bosch CX end), and the LITE variant should continue that. Standout is the broader Merida heritage of a refined trail chassis: @Mr Scooter describes the platform as having "Fact X2 and 38 are top drawer" on his build, which is the kind of chassis that takes high-end suspension well. Questionable is the 400 Wh battery, which is small even by lightweight standards in 2026: the Avinox-powered Amflow PL Carbon ships with 800 Wh removable, and the Cannondale Moterra SL ships with 601 Wh.
Community-verified strengths. First, the broader eONE-SIXTY chassis has a long and well-regarded community reputation. @Mr Scooter, who has raced downhill, says "This thing handles beautifully... I will go out on a limb and say I didn't really like the Levo, Trek Rail and Commencal 29 nor the Pivot". Second, the platform supports significant rider customisation: @RoJo shares setup tips, @Astro66 went to Shimano XT Di2 Electronic Transmission with Coastshift on his 2025 eONE-SIXTY 400. Third, the five-size run including XShort and XLong fits riders that other brands' four-size runs miss.
Caveats and known gripes. The 400 Wh battery is small. @Re-Cycle notes the Merida eONE-SIXTY internal cable routing required removing the motor to add a cable run, which is a non-trivial maintenance job. @RoJo reports needing Polaris enduro straps around the battery to stop the system turning off on big drops, a battery-lock issue on older eONE-SIXTY chassis that should be addressed on current LITE bikes but worth checking at delivery. The deeper concern is resale value: @Astro66 notes selling his 2025 eONE-SIXTY 400 at AUD $3,900 representing roughly 30 to 40% depreciation in 9 months, which is roughly class average but still a meaningful real-world cost.
Verdict. The eONE-SIXTY LITE is in current production and is one of the most credible Bosch SX-powered all-mountain eMTBs on the market for riders who want Bosch ecosystem reliability in a lightweight package. Buy it if you want a 170/174 mm trail/enduro chassis from a brand with a proven handling reputation, a Bosch SX motor, deep dealer support and a five-size run that fits genuine outliers. Look elsewhere if you need a 600 Wh-plus battery as standard, a sub-£5k price tag (which the LITE likely will not hit at current premium positioning), or a full-power 85 Nm-plus motor.
Geometry read
Size
Descending
74
Slack 64.4° head angle, 174mm travel and a long 1244mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
36
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
98
Rear-long with a planted front in Mid (FC:RC 1.79) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
72
Bosch Performance Line SX and a steep 78.4° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 60Nm of torque.
Best suited toFast, steep, rough tracks — and riders who want maximum composure.
Rewards commitment; it should feel calmer as the speed rises.
Watch out forNot a flickable, playful bike at 26kg — built to plough, not pop.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Lightweight · Gravity bikes (from 7 bikes in the database)
Weight26 kg5.3 kg heavier than average
Battery400 Whabout average capacity
Motor torque60 Nmclass-leading torque
Value for money63/100from £5,500 · comparable bikes ~£6,000
💬 Forum discussion
Official Merida eOne-Sixty thread
1.2k replies · 454.5k views · last reply 8 months ago
Join the discussion →
“For all Merida eOne-Sixty related content! Here's mine. A few things have been replaced which I'll list later.”
— Basy · ♥ 15 · most-liked post
OWNERS’ REPORT
Merida eOne-Sixty (E8000 / EP8 / new-gen) — what owners actually know
2,370 posts · 506 owners · data through Feb 2026
40Creaks, knocks and bearing wear: scattered, no single cluster · typical onset: From new (assembly) through normal service intervals.
31LEGACY (Shimano E8000 and EP8 eras): motor failures (internals covered in the Shimano E8000 and EP8 owners' reports) · typical onset: Anywhere from a few hundred km to a few years; heat on long climbs is a common trigger.
19LEGACY (E8000 era): external battery cover loss and battery-mount rattle · typical onset: From new on rough terrain.
Current generation: an owner who ran a 2024 e160 (EP6) for 18 months then a 2025 e160 (EP801) called both 'brilliant EMTBs' and felt a clear 100W climbing gain…
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
XShortShortMidLongXLong
Toptube546 mm567 mm589 mm610 mm632 mm
Reach419 mm439 mm459 mm479 mm499 mm
Stack624 mm628 mm633 mm637 mm642 mm
Seattube400 mm410 mm425 mm445 mm465 mm
Chainstay446 mm446 mm446 mm446 mm446 mm
Headtube Angle64.4°64.4°64.4°64.4°64.4°
Seattube Angle (eff)78.5°78.5°78.4°78.4°78.3°
Wheelbase1199 mm1221 mm1244 mm1266 mm1288 mm
Headtube100 mm105 mm110 mm115 mm120 mm
Front Centre753 mm775 mm798 mm820 mm842 mm
FC:RC1.691.741.791.841.89
Trims · 4
400
£5,500
575
£6,500
675
£7,300
875
£8,800
MotorBosch Performance Line SX · 60 Nm · all trims
Battery400 Wh · all trims
Travel F/R170/174 mm · all trims
FrameCarbon · all trims
ForkRockShox Psylo Silver R, 160mm travel, tapered, 44mm offsetRockShox Psylo Silver RMarzocchi Z1 eMTB, 170mm travel, air, tapered, 44mm offsetRockShox ZEB Select, 170mm travel, air, tapered
ShockRockShox DeluxeRockShox DeluxeMarzocchi Bomber AirRockShox Super Deluxe Select
HeadsetAcros ICR MERIDA EXTERNAL neck w/ Blocklock · all trims
StemMERIDA EXPERT eTR II, 40mm, 0°, 35mm clamp · all trims
HandlebarMERIDA EXPERT eTR, 780mm · all trims
GripsMERIDA EXPERT EC · all trims
SaddleMERIDA COMP SLMERIDA COMP SLMERIDA COMP SL with minitool, V-mountProxim Nembo, V-mount adapter
SeatpostMERIDA EXPERT TR II, 34.9mm, travel 125-230mm depending on frame sizeMERIDA EXPERT TR II, 34.9mm, travel 125-230mm depending on sizeMERIDA EXPERT TR II, 34.9mm, travel 125-230mm depending on sizeMERIDA TEAM TR II dropper, travel 30-230mm (varies by size)
BrakesSRAM DB4 StealthSRAM DB4 StealthSRAM DB6 StealthShimano XT
Rear derailleurShimano CUES U4000 GSShimano CUES U6000 GSSRAM Eagle 70 TransmissionShimano XT RD-M8130 LinkGlide 11-speed
CrankShimano FC-EM600, 165mmShimano FC-EM600, 165mmShimano FC-EM600, 165mmShimano FC-E8150, 165mm
ShiftersShimano SL-MT500-L / Shimano CUES U4000-9Shimano SL-MT500-L / Shimano CUES U6000-10SRAM Eagle 70 Transmission Shifter / SRAM Dropper Lever MMXShimano SL-MT500-IL / Shimano XT M8130 11-speed
CassetteShimano LG400-9, 11-46T, 9-speedShimano CUES LG400, 11-48T, 10-speedSRAM CS XS-1270 T-Type, 10-52T, 12-speedShimano LG700, 11-50T, 11-speed
ChainShimano LG500Shimano LG500SRAM Eagle 70 FlattopShimano LG500
DrivetrainShimano Deore 12-speedShimano CUES U6000 GS; Shimano FC-EM600, 165mm; Shimano SL-MT500-L / Shimano CUES U6000-10; Shimano CUES LG400, 11-48T, 10-speed; Shimano LG500SRAM Eagle 70 Transmission; Shimano FC-EM600, 165mm; SRAM Eagle 70 Transmission Shifter / SRAM Dropper Lever MMX; SRAM CS XS-1270 T-Type, 10-52T, 12-speed; SRAM Eagle 70 FlattopShimano XT RD-M8130 LinkGlide 11-speed; Shimano FC-E8150, 165mm; Shimano SL-MT500-IL / Shimano XT M8130 11-speed; Shimano LG700, 11-50T, 11-speed; Shimano LG500
WheelsShimano TC500-B front / TC500 rear hubs, MERIDA EXPERT TR II rims29" front / 27.5" rear (mullet)29" front / 27.5" rear (mullet)Shimano XT hubs, Reynolds 309 Enduro Comp rims
TyresFront: Maxxis Assegai 29x2.5" TR EXO+ 3C MaxxGrip; Rear: Maxxis Minion DHR II 27.5x2.4" 3C DD TR MaxxTerra · all trims
Weight26.2 kg26.7 kg26.1 kg26 kg
Price£5,500£6,500£7,300£8,800
Rides similarly
Spot a mistake?
